1998 Chevy Blazer Oil in the radiator
1998 CHEVROLET BLAZER
116,000 MILES • 6 CYL • 4WD • AUTOMATIC
GOFASTER60
Hello, This question is for a 1998 S10 Blazer. I have oil getting into the radiator but not getting coolant in the oil? It has been suggested that it could be a head gasket but I'm wondering if that is the case why coolant isn't getting into the oil. The oil accumulates in the radiator at about .25 - .33 quarts per scheduled oil change. Could it be a faulty sensor?
Sep 2, 2010 at 5:18 PM
Are you sure it is motor oil and not trans fluid?
Sep 3, 2010 at 10:44 AM
GOFASTER60
No. Not sure! Although it leaks very little oil externally and as mentioned it appears to be using some oil and the exhaust pipe appears clean. It could be tranny fluid. I dont recall the tranny fluid ever being low when checked since I bought the vehicle about 2.5 Yrs ago. I'll have to keep an eye on that.
Sep 3, 2010 at 11:21 AM
If it is engine oil, then it is from a bad head or intake gasket. If it is trans fluid, then the radiator has internal damage.
Sep 3, 2010 at 12:50 PM
GOFASTER60
OK! Thanks!
Sep 3, 2010 at 12:57 PM
You're welcome, and I look forward to hearing from you.
Sep 3, 2010 at 1:23 PM
