1998 Chevy Blazer no fuel
1998 CHEVROLET BLAZER
11,700 MILES • 6 CYL • 2WD • AUTOMATIC
INFINITY15
i am not getting any fuel to carbeurator. i have gas and pressure out of the filter, but nothing to carb. car will start if i put gas into carb but only run till that is used up. thanks chuck baker
Jul 11, 2008 at 11:38 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:b4cd5e8e36="infinity15"]Engine Performance problem
1998 Chevy Blazer 6 cyl Two Wheel Drive Automatic 117,00 miles
i am not getting any fuel to carbeurator. i have gas and pressure out of the filter, but nothing to carb. car will start if i put gas into carb but only run till that is used up. thanks chuck baker[/quote:b4cd5e8e36]
You will not see gas in what you are calling the carborator what you are looking into is the throttle body. Gas is sprayed directly into the Cylinders VIA fuel injectors. the injector are located under what is called the Plenum which is what the throttle body is bolted to.
You will need to check the fuel pressure at the test connection which is on the drivers side rear of intake.
Jul 11, 2008 at 11:57 AM
MASTERTECHTIM
  • 4,750 POSTS
is the theft light on the dash flashing or does it go out after key is turned to run? is the check engine light lit up on the dash board?
Jul 11, 2008 at 11:58 AM
INFINITY15
[quote:0b2d05f139="mastertechtim"]is the theft light on the dash flashing or does it go out after key is turned to run? is the check engine light lit up on the dash board?[/quote:0b2d05f139]
i don't have a theft light and check engine goes out when car starts. this same thing happened 3 months ago, but restarted 2 days later and ran till yesterday.
Jul 11, 2008 at 12:15 PM
