1998 Chevy Blazer 4 wheel drive
1998 CHEVROLET BLAZER
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
DERANGE
my truck is stuck in 4 wheel low. i have replaced everything. what would cause it to just pop into 4 wheel low and how should i attempt to get it out. thank you
May 4, 2010 at 8:37 AM
SWILLIAMS
  • 597 POSTS
What do you consider everything?
If you replaced the encoder motor you would have needed to place the shift shaft into 2Hi to install it.
If you did this and it still is stuck in 4Lo then the shift linkage in the transfer case is probably broken.
May 10, 2010 at 8:30 PM
