I have had my Blazer for a few years and everything was fine until a few months ago. The Mechanic replaced a master cylinder and brake line - needing to drop the fuel tank to do it. When I picked it up a new problem arose. It has problems turning over and would stall intermittently with no rhyme or reason. I had it in again. The mechanic did a computer test - said it was missing on two cylinders. He tuned it up. Replaced the fuel filter, fuel pump, and full tune-up. I am still having the same problem a couple thousand dollars later. What is going on? He said he can't figure it out. When it stalls many times all the dash lights will come on, the air bag light being the first light and then beeps - then it will kill altogether. I don't have a problem starting it again. I could stall at a light, or try to stall while I am crusing along on the highway.
Nov 22, 2009 at 5:17 PM
