1997 Chevy Blazer o2 sensor / warning light
1997 CHEVROLET BLAZER
GOBOLEKO
Computer problem
1997 Chevy Blazer 6 cyl Four Wheel Drive Automatic 54k miles
My grandfather recently passed this low milage truck my way and it is in exceptional shape overall. It had a small exhaust leak, which I took to my local shop to have repaired. After driving the now quiet truck for an hour or 2, the check engine light comes on. I return to the shop and they inform me there is an 02 sensor issue, but that I may want to drive it a while and just have the codes reset, which I do.
After a couple of weeks of having the codes reset at my local auto-zone, I finally replaced the sensor (bank 1, #3) Within a few miles of having the code reset, the warning light is back on with the same code.
I replaced the sensor located between the converter and the muffler. Was this the right one?
I'm a fairly competent weekend wrench, but I'm at a loss on this one. Computers and electronics are not my strong suit in auto repair.
I'm also strapped for cash, being a full time student and really don't want to have to go to a GM dealership and bow before their service writers.
Any ideas? (the diagnosis code is P0144)
Thanks,
Goko
Jan 8, 2008 at 9:33 AM
SERVICE WRITER
  • 9,123 POSTS
Bank 1 sensor three is the sensor behind the converter. Additional info:
https://www.2carpros.com/forum/automotive_pictures/30961_po144_1.jpg
Jan 8, 2008 at 9:58 AM
SERVICE WRITER
  • 9,123 POSTS
[quote:b987b110a0="goboleko"]Thanks for the info on the O2 sensor.
The first thing you mentioned was checking fuel pressure, which reminded me that my fuel pumphas started getting noisy. When the truck is running, I can hear the whine of the fuel pump. I suspect it is about to take a dump do to the noise.
In your opinion, should I go ahead and drop the tank and replace the pump? I figure it's going to crap out on me in the near future anyway, so I'll replace it, have the warning light reset and see what happens.
Any advice on dropping the tank?
Sincere Thanks,
Jason[/quote:b987b110a0]
Noisy pump is often a sign of the pump on it way out.
Tips...Have plenty of time to work.
Replace the filter at the same time. If you are in any are where corrosion is a problem, this may be a rough job to do on the ground. You may run into problems with the straps. The tank, lines and sending unit may need replacement as you get into the project.
Use a delco pump.
Make sure you have plenty of room to work with to get the tank out.
To release the tank filler neck from the tank, use a haose separator used for radiators to break the seal on it , looks like a bent up screwdriver with a point on it.
Jan 12, 2008 at 11:38 AM
