1997 Chevy Blazer how to change rear driverside tires
1997 CHEVROLET BLAZER
TRUCHO712
Tires and Wheels problem
1997 Chevy Blazer 6 cyl Four Wheel Drive Automatic
i need help on changing the rear driverside tire i dont know where to put the jack im afraid of busting something
Jun 4, 2010 at 7:08 PM
OBXAUTOMEDIC
  • 3,711 POSTS
You should be able to place the jack under the Axle and jack it up with no problem.
When starting bring jack up to axle and jack up until the axle just starts to move. Then loosen the Lugs on the wheel once all lugs are loose finish jacking till wheel is off ground by a few inches.
Jun 4, 2010 at 7:32 PM
