Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Chevrolet
Blazer
Engine Cooling
Cooling Fan
Clutch
Replace/Remove
1997 Chevy Blazer fan replacement
1997 CHEVROLET BLAZER
121,000 MILES • 6 CYL • 4WD • AUTOMATIC
ERIC18360
MEMBER
1 POST
FOLLOW
ok, so the fan clutch is threaded to the water pump. what is the best way to keep the shaft from turning while trying to unscrew the assy?
Jul 4, 2008 at 9:19 AM
SWILLIAMS
CERTIFIED EXPERT
Leave the belt on and give the wrench a good whack to break the fan free. If the belt is alredy off you can use a strap wrench.
Jul 5, 2008 at 10:40 AM
