Brake pads are not worn, front discs are not worn. Squeeling occurs when driving and ceases when pedal is slighly pushed (1/4 inch). When pedal is pushed slightly and the gas pedal is constant (cruise control) the squeeling stops and the RPM increases about 400-500rpm. The discs, calipers and wheel are not hot. Is this an ABS adjustment problem or parts problem? How can I test for this?
Oct 18, 2008 at 6:59 PM
