1996 Chevy Blazer tail lights not working
1996 CHEVROLET BLAZER
122,000 MILES • 6 CYL • 4WD • AUTOMATIC
ANDREW1987
brakes lights aren't working and fuses,bulbs, and wiring all seem to be good on the truck. We also replaced the rear u-joint, but there is still a vibration coming from the back end of the truck. What do you think it could be or how can we fix it.
Sep 24, 2009 at 12:37 AM
PISTOLLIANONE
  • 4 POSTS
This happen to me as well, not on the blazer but another GM product. My brake lights would not work, I changed bulbs, fuses, even a brake switch underneath the brake pedal. No luck on those items. I was wiggling the turn signal and found that in certain positions the brake lights would come on. There was a short in the turn signal module, after replacing the module that is in the steering column my brakes work perfectly. Being a GM product I'm wondering if this is a lateral problem. I hope this helps.
Sep 30, 2009 at 8:27 PM
