1996 Chevy Blazer rough idle
1996 CHEVROLET BLAZER
166,000 MILES • 6 CYL • AWD • AUTOMATIC
JB5537
Blazer starts fine then goes immed to a rough idle. Giving it gas and getting rpms up will smooth it out in a minute or so. Black carbon smoke from tailpipe on warmup until it is smooth. Going back to idle it gets rough again. Possible iac valve?
Jan 28, 2010 at 6:54 AM
MMPRINCE4000
  • 8,548 POSTS
Do you have a check engine light? If not is it working (when ign. is turned to on, light should illuminate).
This is most likely a sensor out of range, like coolant temp sensor for example.
Black smoke indicates a rich mixture and most sensors responsible for air/fuel will go to a default rich setting if bad.
This is done to prevent a lean mixture which can cause severe damage to engine.
If light is on get codes read at most autoparts stores for free.
Jan 28, 2010 at 9:08 AM
