[quote:05134fd996="nooilpressure"]Engine Mechanical problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic 125123 miles
when I let off the gas at a stop sign my oil pressure gage goes to zero when I accelerate it goes back up same around turns...my oil level is acceptable what could this be?[/quote:05134fd996]
What do you mean by acceptable? It is either full or it needs oil. If you are a qt or more low then fill it and see what happens.
If all is good with oil level and it has been change on recommended schedule then it could be either the Oil Pressure Switch or the Oil Pump.
Switch is cheaper and easier to change.
post responses and results here....
Jun 6, 2008 at 6:00 PM
