1996 Chevy Blazer grinding and stuck in 4x4
1996 CHEVROLET BLAZER
GERBRANDT04
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic
When driving in 4x4 after about 5-10 minutes i hear loud grinding noises. I try to put it back into 2 wheel drive but it stays in 4x4. If i keep driving it will stay in 4x4 for another 5-10 minutes and then it sounds louder than a shotgun when it finally kicks out! Possibly my transfer case?
Nov 10, 2009 at 9:44 AM
Have you tried to back the vehicle up when you disengage the 4wd? Is the transfer case full? Is the linkage to the transfer case properly adjusted?
Is this a manual shift 4wd or electric?
Nov 13, 2009 at 8:14 AM
GERBRANDT04
Backing up does not work, the transfer case is full, and it is a push button 4x4. I have not checked the linkage
Nov 13, 2009 at 8:20 AM
