1996 Chevy Blazer gas filter
1996 CHEVROLET BLAZER
GMC1257
Engine Mechanical problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic
how to change gas filter.
Dec 11, 2008 at 12:02 PM
JDL
  • 16,098 POSTS
The filter has threaded fittings, all you need is a couple of wrenches. Make sure there is no pressure on the system, before you take any connections loose. Loosen the gas cap.
The filter, shows to be located on the driver-side frame-rail underneath, just a little past the front tire.
Dec 11, 2008 at 1:26 PM
SWILLIAMS
  • 597 POSTS
Located just about directly under the drivers side door.
Even if you follow the correct procedure to drop the fuel pressure some is still going to leak out.
Make SURE you have the proper wrenches. The fittings use O-rings to seal but if you bend and crack the lines they can be a PIA to replace.
Dec 11, 2008 at 9:59 PM
