1996 Chevy Blazer Fuel Injector Solenoid
1996 CHEVROLET BLAZER
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
BURNING
  • 5 POSTS
I have a 96 Chev Blazer. I have replaced the fuel injector spiders 4 times in the last year and a half. When I put a new or tested used into truck it runs great for 2 to 8 months and then fails again. I have checked the fuel tank and fuel return line they look fine. What could be causing the fuel injector solenoid to fail? I do not receive any ODBii codes.
Dec 10, 2008 at 3:06 PM
JAMES W.
  • 2,394 POSTS
Is it the same injector(s) all the time or a specific one? Also, I'm not sure what you mean by "spiders". And, are the injectors plugged or the coils burned out Please advise.
Dec 10, 2008 at 3:39 PM
BURNING
  • 5 POSTS
Gas goes to a single solenoid and then goes to six lines that go to injectors (it looks like a spider.)
Dec 10, 2008 at 6:48 PM
JAMES W.
  • 2,394 POSTS
I've only heard that term used on diesels, now I know. Anyway, you didn't give me the info on the the injector(s). Please advise.
Dec 10, 2008 at 7:39 PM
BURNING
  • 5 POSTS
The gas goes from fuel pump to the fuel injector / fuel regulator which has a solenoid on the assembly (spider) which is failing. The resistance on the solenoid goes from about 1.5 ohms to 30,000 ohms. The fuel injector nozzles check out fine.
Dec 10, 2008 at 8:17 PM
JAMES W.
  • 2,394 POSTS
This may sound like a stupid question, but how can the resistance go from 1.5 ohms to 30,000? I have pondered over several diagrams and what you seem to be testing is a fuel pump/oil pressure cutout switch. How many wires go to this unit? If my diagram is correct, this switch will shut off the fuel if oil pressure drops beyond a certain point.
Dec 10, 2008 at 11:07 PM
BURNING
  • 5 POSTS
I am not testing fuel pump, the spider is isolated from electric circuit when it is tested with an ohm meter.
Back to the original point, what can be making the solenoid on the the spider fail. There is no restrictions on the fuel flow and the fuel pressure is at 60psi, so it must be in the electrical circuit. I'm not sure where to start looking. A dealer tried replacing the computer but that made no difference.
Dec 11, 2008 at 9:31 AM
SWILLIAMS
  • 597 POSTS
burning,
Have you checked to voltage and grounds going to the spider? You may have a bad harness.
Check the harness for any worn through insulation as well. Because the system actually uses ground switching a grounded wire could be causing high current, also shorting out the coils
Also, where have you been buying the replacements?
Dec 11, 2008 at 10:07 PM
BURNING
  • 5 POSTS
Thanks SWilliams for the direction. I will investigate.
Dec 11, 2008 at 10:32 PM
