1996 Chevy Blazer DTC P1886 - 3-2 Shift Solenoid Valve Asse
1996 CHEVROLET BLAZER
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
TXJOHNSONS
Service engine soon light is on.
I understand that the DTC P1886 - 3-2 Shift Solenoid Valve Assembly CKT Electrical could be a loose wire that is causing the problem.
Can you tell me where the shift solenoid is located. Thank you!!
Aug 2, 2008 at 8:01 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:39ecfa6ac3="txjohnsons"]Transmission problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic 150000 miles
Can you tell me where the shift solenoid is located. Thank you!![/quote:39ecfa6ac3]
It is located on the Vavle Body, you will have to drop the transmission pan to get to it.
Aug 2, 2008 at 8:39 PM
TXJOHNSONS
Thanks for the quick response!!
Where does the wire connect under the hood. I am wondering if it was accidentially pulled loose when working on the compressor.
Aug 2, 2008 at 8:50 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:11364cc49e="txjohnsons"]Thanks for the quick response!!
Where does the wire connect under the hood. I am wondering if it was accidentially pulled loose when working on the compressor.[/quote:11364cc49e]
There shouldn't be any wiring as far as the Tranny anywere near the compressor.
Check connections on tranny itself.
Aug 3, 2008 at 8:45 AM
