1996 Chevy Blazer Code P0300, Cylinders misfire detected-ra
1996 CHEVROLET BLAZER
18,900 MILES • 6 CYL • 2WD • AUTOMATIC
JUCHAM50
This is what i have done so far, I tested the ignition system and all cylinders fire except # 1 and # 2. I inspected the Distritor cap and rotor and they seen to be ok. Also i could not locate the Fuse/Relay for the Fuel. So when i tested each cylinder the vehicle started. What do you suggest from here.
Mar 6, 2010 at 6:43 PM
LEGITIMATE007
  • 5,121 POSTS
multiple misfire can be a few things, I would first check the plugs and wires, then the intake manifold, for vacuum leaks, then check the egr.
Mar 6, 2010 at 8:08 PM
