1996 Chevy Blazer Brake lights
1996 CHEVROLET BLAZER
258,000 MILES • 6 CYL • 4WD • AUTOMATIC
KHENSLIN
Recently my brake lights have stopped working along with my emergancy flashers. The rear turn signal lights work. Also, the rear lights work when the headlights are turned on.
I installed a new fuse, a new brake light switch, a new turn signal switch and a new flasher switch.
Nothing seems to work. Any suggestions?
Dec 1, 2009 at 1:02 PM
JDL
  • 16,098 POSTS
Welcome to the forum, thanks for the donation, does the high-mount brake lite work? If not, check the feed circuit to and from the brake switch. orange wire is feed to the switch, hot all the time. White wire goes hot when brake switch is activated. Use a testlite on those circuits.
Dec 1, 2009 at 1:13 PM
