1995 Chevy Blazer Engine performance idle, fuel etc
1995 CHEVROLET BLAZER
105,000 MILES • 6 CYL • 2WD • AUTOMATIC
ICURMA
Hi there, I have a chevy blazer 1995 4.3l vortech 105000 miles, 4 doors 2x4. In summer time, I did a tune up. I put new wires, plugs, fuel filter, air filter. One month ago I took it to the mechanic and changed intake gasket and timing chain. After I took the car out and drove it, it stalled and I started with no problem after that. Since then it has done the same thing two more times. This happened only when I stopped and usually the battery gage goes low while stopped at a traffic light. And the car feels like it will stop running or like it doesn't take enough air or fuel. I did put fuel injector cleaner .I changed the IAC but it is the same no changes. One time turned on check engine light. Would you please give an idea what it might be? Thank you.
Jan 14, 2010 at 1:52 PM
PEAR69
  • 1,482 POSTS
Being that the battery gauge goes low, I would suspect the battery connections. Disconnect the battery and make sure the connections are clean. Also inspect where the battery wire connects to the starter.. Test (or have them tested) the battery and alternator.
Jan 14, 2010 at 5:30 PM
