Emergency fuel shutoff
1995 CHEVROLET BLAZER
229,000 MILES • 6 CYL • 4WD • AUTOMATIC
SEVERED89
Ok i rolled over on its side and i was wondering the emergency fuel shut off switch would be located if there is one
Dec 20, 2009 at 11:06 PM
There's no such switch available for your vehicle unless its a ford product
Dec 20, 2009 at 11:21 PM
NATIVESONZ
Does the 96' blazer have a fuel shut off switch..and if so , where is it located on the vechical..thanks
Mar 30, 2019 at 2:37 PM (Merged)
GM doesn't have one.
NATIVESONZ
thank you...
regarding fuel pump..when installing new harness to vec. on new harness there were two black leads on the same as rest the other one size bigger..on harness from vech. that was changing also two black leads, but one with a white stripe, question which black leads go to new harness...from vec. with blk and white to new..same size lead or larger one..may have wire wrong..will this cause a problem ..no power to pump..again thank you
