Hi, Guys!
I've had this problem before and it cost me a lot so i am being very cautious. Here's the deal my car wont start.Before I would use a starting fluid and it would crank but i had to keep pressure on the pedal. So, I changed the fuel pressure regulator and the car started but then it started to stumble, choking. So, I was told it was the fuel pump. So, got the psi tested and it was at 40 psi. I changed it and the fuel filter still hard starting, idling rough but now the car won't start at all. It sat for three days and i went to start it and it started but I had to keep pressure on the pedal. So, I am totally confused as to what is going on so here are the things I changed.
wires, rotor, distributor, spark plugs was wet from flooding and i cleaned them and put them back in. I changed crank case sensor, fuel injectors was checked with noid light, mapp sensor changed, idle air changed, throttle position sensor changed, except the coil, which was changed like in May four months ago. I also changed the fuel sensor relay.
I also noticed when i was stuck and it let me down i did not hear the ful pump click on. So I banged the tank and it acted like it wanted to turn over but wouldn't even with starting fluid..
I also noticed when the fuel pump was changed the assembly unit hose was a little pinched. So I dont know how much this would effect the psi level. So I bought a new unit but haven't changed it yet.
I know this is crazy but I really want to get to the heart of the matter and solve this problem before I burn the car or push it off a cliff..lol..thanks for your help!
Sep 10, 2020 at 12:47 PM
(Merged)
