1994 Chevy Blazer rear tail lights will NOT work...
1994 CHEVROLET BLAZER
200,000 MILES • V8 • 4WD • AUTOMATIC
SCHWEITZER333
how can I fix this....??? the fuses are fine... is there a IN-LINE FUSE ???? same problem on my 1500 1988 pickup...
Nov 14, 2009 at 9:04 PM
JDL
  • 16,098 POSTS
welcome to the forum, did you check the park/lamps fuse and circuit for voltage? You may have to get at the connector for the headlamp switch, check the orange wire for voltage. When you activate the headlamp switch, the brown wire carries voltage to the tail-lamps. Did you check for voltage and ground at the rear?
Nov 15, 2009 at 11:16 AM
