i am trying to get my Brake light and hazards working. I have check the fuses and change the brake switch. I have turn signals and parking lights.
May 16, 2009 at 1:01 PM
JDL
CERTIFIED EXPERT
Hello, did you check for voltage going to the brake switch? With the brake applied, is there voltage coming from the brake switch? You need to check that fuse circuit is hot as well. The lower brake lites and turn signal may use the same bulb filament, just not at the same time.
May 16, 2009 at 1:49 PM
PSHELTON
MEMBER
1 POST
Yes I did even put a new brake light switch, it has voltage. From what I have read I am thinking it could be a multifunction switch. But not sure I am still trying to run the problem down.
