I have a buzzer that worked properly until recently. It used to only buzz when I would leave the keys in the ignition or forget to turn off my headlights and leave the car. It buzzes after turn on the lights when I have started the car. Please help. There is a short somewhere because it recently drained my battery. I had the alternator checked and it is good. I replaced the ignition switch, key cylinder, and the key tab that connects when you put the key in the ignition and the problem was not solved. I have a car alarm, but have removed that also. The car starts and the buzzer still activated when I turn on the lights.
I also have problem with the drive shift engage arm. After I replaced the above items I cannot shift into gear. I plan to take apart again and see what is wrong with shift.
Jan 25, 2010 at 7:04 AM
