My Blazer won't start. When I turn the key, the battery gauge dives all the way down and the engine turns over just a few degrees, but doesn't continue to rotate. I've had the battery charged and tested. They said it was ok. I've had the starter tested, they said it was ok. I jumped the terminals on the starter and got the same outcome. I have 12 volts at the main power wire on the starter and a test light dimly lights up on the signal wire to starter. What do I check next? What's not working the way it should?
Nov 29, 2008 at 3:21 PM
