1988 Chevy Blazer Rotors
1988 CHEVROLET BLAZER
BEARDEDDUDE
Brakes problem
1988 Chevy Blazer V8 Four Wheel Drive Automatic
After removing the pads and caliper, the hub lock, and the two internal snap rings...the rotors still won't come off. It looks like they might be rusted on there, but I wanted to check to see if I was missing anything before I start whacking away. Any information will be helpful. Thanks for your time.
Oct 22, 2008 at 8:04 AM
DOCFIXIT
  • 18,828 POSTS
Remove wheel bearing outer lock nut and inner bearing adjustment ring need sockei J-6893 and adapter J-6893-01
Oct 22, 2008 at 12:24 PM
BEARDEDDUDE
[quote:5efb8f499a="Docfixit"]Remove wheel bearing outer lock nut and inner bearing adjustment ring need sockei J-6893 and adapter J-6893-01[/quote:5efb8f499a]
Thank you. I appreciate the help.
Oct 22, 2008 at 12:38 PM
