Ive had a water pump leak for quite some time. yesterday it finally went out started overheating at a stoplight.. temp went from 210(norm) to 260 in seconds.. I bought a new waterpump, thermostat and bolts and installed... added new coolant to 3 1/4gal. warmed up just fine turned off turned on again was fine. let it run till it hit 210 (w/ heater on) temp kept rising slowly above 210. turned heater off, temp went down below 210 then slowly started rising again above 210 again.. i can't figure out what is causing it to overheat.. thanks
Apr 11, 2010 at 4:39 PM
