1986 Chevy Blazer how much to time a engine
1986 CHEVROLET BLAZER
186,000 MILES • 6 CYL • 4WD • AUTOMATIC
XNOOKX
  • 24 POSTS
i was wandering how much it would cost 2 get my engine timed its a 2.8 liter v6 cause my blazer tries 2 start all the pullys turn but it wont start it trys to so can some 1 plz help me thank u
Apr 18, 2009 at 4:22 PM
Do below to determine if its fuel or spark problem
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Apr 18, 2009 at 5:32 PM
XNOOKX
  • 24 POSTS
i have taken out the spark plugs and clend them and that didnt help i have pourd alil gas n the carb but it did help what it does is when u turn the key it turns over and the pullys turn but it wont start the onjectors do spray out fuel
Apr 18, 2009 at 6:30 PM
XNOOKX
  • 24 POSTS
this blazer has been siting 4 2 years
Apr 18, 2009 at 6:41 PM
Did you check for spark? Check if you have it and then comeback
Apr 18, 2009 at 6:43 PM
XNOOKX
  • 24 POSTS
how do u check for a spark
Nice to hear this stuffs-also check the fuel pressure
Apr 18, 2009 at 6:44 PM
You need a professional help here-get someone that knows a little about cars-Do everrything I've mentioned on my 1st post and then get back with some results.
Apr 18, 2009 at 6:48 PM
XNOOKX
  • 24 POSTS
k thanks
Apr 18, 2009 at 6:49 PM
