Blazer S-10
Brakepedal has bled down to the floor while waiting at traffic lite. Same day I replaced master cylinder, bench bled first. bled the lines coming out of the cylinder,then the two bleeders on the antilock body. adjusted a;ll brakes. Pedal did bleed down first day. Now it is low but does not bleed down as much. Was that the righ bleeding procedure? What are the rubber cups protecting the proportional valve that is located downstream fron the master cyl?
Sincerely,
Roger lebish
Sincerely,
Roger lebish
Aug 14, 2010 at 3:37 PM
