1982 Chevy Blazer it died
1982 CHEVROLET BLAZER
PCSING8808
Engine Mechanical problem
1982 Chevy Blazer
my blazer started puttering on me and then it died. after my husband changed all the fuses. it smells like its not getting any and i thought it mught be the fuel pump fuse but i cant find one. it sounds like it trys to turn over but gives up half way thru. help me
Mar 20, 2009 at 3:54 PM
Do below to determine if its fuel or spark problem
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 20, 2009 at 3:58 PM
MERLIN2021
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
Mar 20, 2009 at 3:59 PM
PCSING8808
thnx so much i will have to try that
Mar 20, 2009 at 4:02 PM
