beretta gt 92, electrical.
1992 CHEVROLET BERETTA
BLISTER
I got some problems with my car and it all started when i forgot to unplug the negative from the battery and whent and unmounted my starter.
While i was taking the starter out i touched some other part and it did a couple of sparks. Now when
i put the key to on just beffore starting the car
the fuel and rpm gouge freak out and the light in the instrumental cluster goes on and off for about 10 sec.
the first try the car does nt start, but it does after.
Was wandering if its possible to pin point me in the right direction ?..
Thx in advance.
May 29, 2006 at 8:09 PM
ELZIEW
  • 17 POSTS
First check your battery connections, both post, and the cable clamps, and that they are good and clean. On the battery cables there will be a smaller wire connecten to each cable, make sure they are in good shape, and have a good connections.
also recheck to see that your reconnections when you installed the starter are good and tight that you have a good ground from battery to engine, and to the body.
Hope this helps.
Good luck
Jun 3, 2006 at 12:14 AM
BLISTER
Thanx you, i will try that. :D
Jun 5, 2006 at 10:25 AM
