1996 Chevy Beretta SPEEDO DOESNT WORK
1996 CHEVROLET BERETTA
BERETTA
Transmission problem
1996 Chevy Beretta 6 cyl Front Wheel Drive Automatic
1996 BERETTA WITH 150,000 MILES . THE SPEEDO QUIT AND THE CAR SEEMS TO BE STUCK IN A HIGH GEAR. IS THE TRANNY BAD OR IS THERE A POSSSIBLE BAD SENSOR CAUSING BOTH PROBLEMS AT ONCE?
Aug 11, 2008 at 7:19 PM
MASTERTECHTIM
  • 4,750 POSTS
my guess is the vehicle speed sensor or the wire connector to it has a broken wire. that is causing both your problems. fix it now or you will burn out the transmission.
Aug 11, 2008 at 7:24 PM
BERETTA
IS THE VSS LOCATED ON THE DRIVERS SIDE OF THE TRANNY AND HOW MANY WIRES DOES IT HAVE
Aug 11, 2008 at 7:31 PM
MASTERTECHTIM
  • 4,750 POSTS
i belive its located under car on top of trans more toward passengers side and there are 2 wires going to it purple and yellow are the colors of the wires if my memory is correct.
Aug 11, 2008 at 7:36 PM
BERETTA
YOU ARE TRULY A MASTER TECH!!!!1
Aug 11, 2008 at 7:40 PM
