1996 Chevy Beretta Overheating engine, Cold air blow out
1996 CHEVROLET BERETTA
156,000 MILES • 6 CYL • FWD • AUTOMATIC
HODES11
My beretta will overheat and air blowing out is ice-cold, all of a sudden thermostat needle drops to normal operating temps and resumes blowing warmer air, than all of a sudden repeat and cold air. It will do this every 2-4 minutes, but i have already stopped driving it. I've already changed thermostat, still not fixed. My next idea is water pump, but i have asked around and i'm hearing blown head gasket or heater core. The coolant doesnt leak, just it bubbles over from over-heating. If its blown head gasket, is it possible to sell car in this working condition?
Jan 26, 2008 at 8:57 PM
BLACKOP555
  • 10,386 POSTS
im thinking you should verify the coolant level by removing the radiator cap and filling up the rim.
Jan 26, 2008 at 9:04 PM
INDIANA*JOSH
[quote:371f251862="hodes11"]Engine problem
1996 Chevy Beretta 6 cyl Front Wheel Drive Automatic 156000 miles
My beretta will overheat and air blowing out is ice-cold ... [/quote:371f251862]
I am having almost the exact same problem with my 1998 Lumina (172000mi). Engine overheats sporadically. Overheating is always associated with frigid cold air from the heater. No coolant leak, but the coolant backs up into the reservoir significantly from the overheating.
I have changed the thermostat, flushed the system, and bled all air out - no improvement. Does anyone have any ideas?
Jan 28, 2008 at 6:23 PM
BLACKOP555
  • 10,386 POSTS
please make another topic and well be glad to help.
Jan 28, 2008 at 6:35 PM
