1996 Chevy Beretta My fuelpump fuse will blow after the car
1996 CHEVROLET BERETTA
15,000 MILES • 6 CYL • FWD • AUTOMATIC
GORMAN225
MEMBER
1 POST
FOLLOW
The car runs great until it warms up. At this point the fuelpump fuse will blow.
Oct 7, 2009 at 2:46 PM
JDL
CERTIFIED EXPERT
Welcome, how long since changing the fuel filter, using a gage and checking fuel pressure? I believe the injectors and fuel pump get voltage from the same fuse.
You might separate the fuel pump circuit, then check the amp draw. You can also do an ohms test on the injectors and compare.
