1996 Chevy Beretta Engine stumbles for a few minutes after
1996 CHEVROLET BERETTA
75,000 MILES • 6 CYL • FWD • AUTOMATIC
LOCCHI
Hi, the stumbling happens when I open the throttle. The engine might rev to 2k rpm then drops slightly. If I give it more gas it does not rev higher and feels like its going to die. If i open throttle fast it stumbles to 3-4k rpm and seems fine. So i hold it at 2.5-3k rpm for a few minutes until the hesitation/stumble goes away.
It happens when I leave school during the hottest part of the day. The engine at that point has been off for about 5 hours.
For cold starts i have to pump the gas peddle. It starts fine if the engine is warm.
I have recently changed the air filter, fuel filter, and the spark plugs. I checked the spark plug wires for damage. The car drives like a champ except for the cold starts.
Aug 4, 2010 at 10:03 PM
Have you checked the fuel pump pressure? HAs the check engine light come on?
Sep 1, 2010 at 7:26 AM
LOCCHI
Hi thanks for replying. I haven't checked the fuel pressure. The check engine light comes on if i accelerate to about 55+. It doesn't come on otherwise.
Sep 1, 2010 at 4:09 PM
There are two things I need you to do. First, take the vehicle to a nationally recognized parts store and have them scan the computer for trouble codes. Let me know what they tell you.
After I know that, I may ask that you check fuel pump pressure. I will provide directions if you need them. Just let me know.
Sep 1, 2010 at 8:30 PM
