1996 Chevy Beretta broke off low side port cap nipple in lo
1996 CHEVROLET BERETTA
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
RANDYROO
any suggestions on this? There is a threaded nipple on the inside of the cap that screws onto the low side charging port which is plastic, it broke off inside the port. I've tried an easy out but it just strips out the plastic and bottoms out into the schraeder. How can I remove?
Aug 14, 2010 at 6:34 PM
HMAC300
  • 48,601 POSTS
try a sharp pic liek thing to get it out. try to unscrew it then if you have a tiny pair of snips or tweezers you might be able to get it out with that if you take your time and are careful. You might also try a small sheet metal or wood screw, but make sure it's a long one so you don't lose it.
Sep 14, 2010 at 5:58 PM
