1995 Chevy Beretta stalls in drive, runs fine in reverse
1995 CHEVROLET BERETTA
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
LKAUEN
our car runs fine in reverser; however, as soon as we put it in any drive position it stalls & sputters.
Apr 26, 2008 at 11:42 AM
ENGINE DON
Try Unplugging the Transmission solinoid sensor which engagues the overdrive gear this should solve your problem, but you will not have overdrive gear and the car will have poor fuel mileage till you replace the solinoid which is located at the front (nose) driver side (left) transmission. hope this helps you. Engine Don
Apr 28, 2008 at 8:21 PM
