my g/f's 1995 berreta has a code in the computer the light comes and goes. while driving. i was going to perform diagnostics on it by connecting the ground terminal with the diagnostic terminal, to make the check engine light flash out the codes. the connector appears to be missing several terminals, including the diagnostic teminal, this car has had several owners in the past. i cant find any evidence that wires have been pulled off the connector. is it possible that someone has tampered with the connector, and why, is the a wire on the pcm that i can ground out to retrieve the code(s), if so what color would it be? thanks, john f
Oct 22, 2010 at 11:04 AM
