1995 Chevy Beretta Horrible Vibration noise
1995 CHEVROLET BERETTA
96,000 MILES • 6 CYL • FWD • AUTOMATIC
REPTAR022000
  • 10 POSTS
If I go straight down the road or turning right there is a horrible virbration/humming sound coming from the passenger front side someplace, but as soon as I turn the wheel to the left it is silent and you dont hear anything. I was told it was probably a wheel bearing so I changed that but it still does it. What else could it be?
Apr 4, 2008 at 6:42 PM
MASTERTECHTIM
  • 4,750 POSTS
whatever bearing you replaced. replace the other one. the noise you are describing is definitely a bad wheel bearing. does the bearing you took out spin freely? if it does then its probably still good. try installing that bearing on the other side. i bet you will find the other bearing is bad. this happened in my shop yesterday. even a trained tech can sometimes misdiagnose the side the noise is coming from. trust me.
Apr 4, 2008 at 7:01 PM
