1994 Chevy Beretta sparke plug
1994 CHEVROLET BERETTA
WAYNE PURDY
Engine Mechanical problem
1994 Chevy Beretta 6 cyl Two Wheel Drive Automatic 98,ooo miles
my sparke plug broke off in hole 4 the botton thread part of sparke is still in cylinder thread hole #4 how is the best way to remove it. also is there a tool that tilts engine forward after dog bone is remove
Jan 25, 2010 at 4:27 PM
HMAC300
  • 48,601 POSTS
if the bottom part still has the socket end on it then by al means use the spark plug socket. If not you'll have to find an easy out to see if that will take it out. Or cut the steel witha small hacksaw blade and bend it back and see if you can get itout that way. the best thing to do to get teh engine forward i've found is to put the car in nuetral, rock the engine forward and place a piece of 4X4 between engine and firewall. Make sure to block the wheels though..good luck and make sure to use anti-sieze copoun when you put eh plugs in the next time.
Jan 29, 2010 at 5:44 PM
