1994 Chevy Beretta Ignition
1994 CHEVROLET BERETTA
17,600 MILES • 4 CYL • FWD • MANUAL
MOUNTAIN MAN1
I have 1994 z-26 Beretta quad 4 2.3 engine. It starts ok the dies after a while. about 10 minutes. After a rest it will start again. Then dies. The car cranks but doesn't start. I am not sure if the ignition module is bad.
I have changed the coil pack and checked to see if the fuel pump is still pumping. I get still get fuel.
Help.
May 23, 2009 at 11:19 AM
JDL
  • 16,098 POSTS
Hello, have you done any basic testing when the vehicle refuses to start? Spark at the plugs--fuel pressure--troublecodes? Maybe your losing the rpm signal, intermittently? When the vehicle refuses to restart, you could also check for an injector pulse, engine cranking.
May 31, 2009 at 12:30 PM
