1994 Chevy Beretta Coolant system
1994 CHEVROLET BERETTA
122,000 MILES • 6 CYL • FWD • AUTOMATIC
SKD
I have a 1994 Chevy Beretta and recently had to replace the thermostat.
After this replacement I am having trouble with it overheating at times. Seems that in the morning I will start it and let it warm up for about 15 minutes before heading out to work. But I get in and no heat. The gage will read at half or slightly under.
Then start to drive and it will peg the gage. Sometimes revving it up or hard acceleration will cause heat and the gage to return to normal temp.
Also I have noticed that the tem will fluctuate while I have heat and am driving. Needle on the gage will bounce between just under half way to three quarter. Back and forth.
Do I have air in the system? And how do I get it out?
Jan 20, 2008 at 4:32 PM
BMRFIXIT
  • 19,053 POSTS
Check coolant level make sure you have opened the bleeders
and top off coolant. The first thing you need to do is check the coolant level in both the overflow and in the radiator. Do this only when the engine is cool! If it's low, you probably have a leak somewhere and need to fix that first.
Jan 26, 2008 at 10:04 PM
