1993 Chevy Beretta 93 Beretta Highbeam Switch
1993 CHEVROLET BERETTA
170,000 MILES • 6 CYL • FWD • AUTOMATIC
ACESHIGH717
  • 24 POSTS
A female friend has a 1993 Beretta and the highbeam switch does not work. Only the low beams will light up. What needs to be replaced and how much trouble is this? I believe it is the turn signal handle that also works the headlight beams.
Thank you in advance.
Scott
Apr 15, 2008 at 5:37 PM
MASTERTECHTIM
  • 4,750 POSTS
very easy to replace the high beam switch. its located at the base of the steering column and is connected to lever via linkage rod. a lot of times its just out of adjustment.
Apr 15, 2008 at 7:44 PM
