1990 Chevy Beretta Starts Hard, cranks forever, Runs fine w
1990 CHEVROLET BERETTA
13,900 MILES • 6 CYL • FWD • AUTOMATIC
TITLEIST181818
1990 Chevy Beretta, 3.1 V6, Starts hard especially as it gets colder outside. Cranks and cranks forever. once started runs fine.
Starts okay when engine is warm...
Nov 24, 2008 at 2:22 PM
Have the coolant temperature sensor and fuel pressure tested-
Nov 24, 2008 at 2:25 PM
TITLEIST181818
Had Coolant issues worked on last year. Fuel pressure seems fine as it will flood if I switch the key on off 3-4 times before I try to start it... If I do that it will NOT start, otherwise just turning the key it will eventually start after 10 seconds of cranking. Plugs ? Fuel Filter ?
Nov 24, 2008 at 2:35 PM
You need to check the actual fuel pressure with a fuel presure gauge and comeback with the readings this is where we start-
Nov 24, 2008 at 4:53 PM
