1990 Chevy Beretta Heater Core not hot
1990 CHEVROLET BERETTA
JHAMPTON78
Heater problem
1990 Chevy Beretta 6 cyl Front Wheel Drive
I was wondering why my heater core isn't getting hot. I have no heat in my car. The heater core is brand new. The thermostat is brand new. The 2 radiator hoses are hot but the hoses going into the heater core are cold. Please help me
Jan 6, 2010 at 7:59 PM
HMAC300
  • 48,601 POSTS
first thing to check is if your coolant is low or not. that is the number 1 problem with no heat. You may have changed the core an dnot filled it correctly . It could also have an air lock in it. There is a bleeder valve by the passenger side front to bleed off the air. If you hav to add quit a bit of coolant then take it to a pro and let him pressure check it for leaks. It's leaking someplaceif it's low.
Jan 19, 2010 at 2:59 PM
