1989 Chevy Beretta right brake light problem
1989 CHEVROLET BERETTA
125,000 MILES • 6 CYL • FWD • MANUAL
ZHAO
I just bought a 89 chevy beretta GTU, my girlfriend realized my *right* brake light didn't work. I replaced the bulb and still no *right* brake light. whats really got me stumped, is all my other lights (and) turn signals work, even the *right* turn signal. for some reason, that *right* *brake* light won't work.
P.S. I have worked on cars at auto shops for some time, I just wasn't ever good with electrical.
seriously confused.
thnx,
Chris
Apr 24, 2009 at 7:51 PM
ATKAPARKING
  • 64 POSTS
Electrical is really hard because you can't see it. I've been working on cars a long time and it still stumps me. That's okay, though, the important thing is not to give up. On this car, I'd check for power and ground in the socket itself. (Also check for corrosion inside the socket). You'll need a voltmeter or a test light that'll show ground side--mac makes (or made) a great one. With a helper pushing down the brake pedal or a long extension pushed between pedal and seat, verify that you have 12v power inside the socket--I can't remember exactly, but I think it's the point in the base. Then check for ground using ohmeter where the slots are (for the pins on the brake bulb). (Double check for power and ground on each point, in case I misremembered). Then check for power and ground on the wires leading to the socket. This will tell you if you need a new socket (junkyard) or further wiring diagnosis. Good luck.
Apr 30, 2009 at 12:51 PM
