1989 Chevy Beretta Fuel pump cutting in and out
1989 CHEVROLET BERETTA
STONEY1981
Electrical problem
1989 Chevy Beretta 4 cyl Two Wheel Drive Manual
1989 Beretta 2.0 FI ... Brand new fuel pump/filter/strainer... The pump is still cutting in and out when vehicle is running... I hot wired the pump and it pumped strong for a long time... is it a sensor?????
Oct 3, 2010 at 1:00 PM
JDL
  • 16,098 POSTS
Check for any applicable trouble codes. Check the circuits at the fuel pump relay. Check the ecm fuse, should be close to fuel pump relay at firewall. The fuse is location C4. Not only check the fuse, check for voltage going to the fuse.
https://www.2carpros.com/forum/automotive_pictures/170934_beretta_component_location_1.jpg
Oct 3, 2010 at 2:22 PM
STONEY1981
so i put a new fuel pump relay in and still not working correctly, next i will try your idea cause it makes perfect sense.. now, if the computer is sending a fault that is cutting off the pump, do you think after putting the new pump in i should have to reset the computer??
Oct 3, 2010 at 3:55 PM
JDL
  • 16,098 POSTS
Any voltage at the fuse I mentioned? You shouldn't have to reset anything.
Oct 3, 2010 at 4:04 PM
