2005 Chevy Astro Air
2005 CHEVROLET BEL AIR
BRIAN LEVERANCE
Air Conditioning problem
2005 Chevy Astro 6 cyl Two Wheel Drive Automatic
Brought my car to the dealer in Oct. they told me I needed a new compresser. (Bearing was squeeking but air worked fine. covered under ext waranty) They told me one of the air lines was rubbing against something and that I should replace but didn't need to immidiately. No one was available to show me the problem when I picked up the car.
Didn't use the car much or the air over the winter months and discovered in March the air doesn't work.
Now they tell me there's a hole in the line.
1. Have you ever heard of the air lines on the Asto's getting holes in the lines because of rubbing? Car has 46k miles.
2. Can I repair the line at the break rather than spend $650
Apr 21, 2008 at 12:25 PM
LOUT5369
  • 217 POSTS
yes it is possible for the line to get a hole in it if it is rubbing on something,I don't know why the dealer didn't reposition the line to prevent further damage,Once an A/C line has a hole in it it has to be replaced,the pressures are to high to make an effective repair,the minute you'd turn the A/C the line would come apart,.and you'd be back to square one.
Jul 24, 2009 at 6:29 AM
