1962 Chevy Bel Air Need to know whether a certain engine wi
1962 CHEVROLET BEL AIR
ROBERTJDICKERSON
Engine Mechanical problem
1962 Chevy Bel Air 6 cyl Two Wheel Drive Manual
I need to know if a 250 straight six engine can replace a 235 straight six.
Oct 10, 2008 at 8:15 PM
Hi:
What year is the 250? also, my only concerns deal with the bell housing bolting and if you will be able to find motor mounts to fit both the vehicle and engine. Most likely, they will need to custom made.
Nov 29, 2008 at 5:16 PM
MICKEY-D
  • 304 POSTS
Most Chev bell housings are the same, but if the trans is automatic, the flex plates might have different holes for the torque converter bolts. I don't think motor mounts should be a problem, but the oil pans could be different in depth, and where the sump is. Good luck.
mickey-d
Dec 9, 2009 at 9:57 PM
