1959 Chevy Bel Air ignition
1959 CHEVROLET BEL AIR
RMALDO
Electrical problem
1959 Chevy Bel Air V8 Two Wheel Drive Automatic
I have a 1957 bel air....my car Turns over but wont start,unless i back off on the key, repalce ignition, triple check the wires from the stater,ignition,and distributor. soulds if there a voltage block when ignition on during the turn of the key, when i release it it starts?
May 1, 2008 at 6:51 PM
BNVLE64
  • 5 POSTS
Ignition switch on 57 Chevy is made to be held btiefly to engage the starter solenoid. Releaseing after enginge starts keep from burning out stater solenoid and starter motor. Is you Chevy box stock or has it been modified? Original ignition should have 4 positions, lock off, on, start. since you have replace the ignition switch, did you replace with a 2 wire or 3 wire switch. If a 3 wire switch, ther should also be an accessory position, sounds like a 3 wire switch and you have crossed the wires, try swappin terminals on the hot side.
Jul 19, 2008 at 3:42 PM
TIMBUCK72
did you put a hei/eletronic distribtor if so is the resistor/voltage drop hooked up ? if its hooked up you will need to conect the two wires toghether the hei dist needs constant 12volts going through the resistor will drop the volts to 6v i had the same problem with my 55 chevy hope this works
Jun 15, 2009 at 6:31 AM
LOUT5369
  • 217 POSTS
check to make sure ign wire on solenoid is connected,this is the wire closet to the exhaust manifold,the thin wire near the block on the solenoid is solenoid trigger,the other wire on the solenoid is ignition voltage during starting,good luck,Lou
Jul 24, 2009 at 6:15 AM
