2007 Chevy Aveo Radiator Water
2007 CHEVROLET AVEO
15,000 MILES • 4 CYL • 2WD • MANUAL
ANNAAMED
I have same problem of water evaporation. I have not seen any leak and look it is a manufacturing problem, please reply.
Thanks
Aug 26, 2008 at 2:12 PM
SNAPONADDICT
  • 5 POSTS
depending on what engine you have you mav have a leak around the two coolant plugs to a coolant passage under the valve cover i have run in to it a few times the fix is to remove the plugs apply thread sealant and reinstall i beleive the torque is 76 ft-lbs hope this helps
Feb 4, 2009 at 10:46 PM
